Use this procedure to enable FHS to enable DHCPv6 Guard, RA Guard, and ND-inspection globally, and to configure the lifetime for these policies.
  1. From the navigation pane, expand Configuration > IPv6.
  2. Select FHS.
  3. Select the Globals tab.
  4. Select FHS global options.
  5. Select Apply to save the changes.
  6. Optional: Select Refresh to update the results.
Use the data in the following table to use the Globals tab.
Name
Description
Admin
Enables or disables the FHS policy.
RAGuardAdmin
Enables or disables the RA Guard policy.
DHCPv6GuardAdmin
Enables or disables the DHCPv6 Guard policy.
NdInspectAdmin
Enables or disables Neighbor Discovery inspection.
